OEM G35/350z spring rate in kg? Conversion?
Old Oct 5, 2006 | 11:39 PM
TwoK4drSi's Avatar
I found a suspension I want to try but it's in kg and I want to compare or is there a conversion formula I should use? The fronts of these aftermarket coilovers are are 10kg and the rear is 8kg. Any help is appreciated. TIA.
Old Oct 6, 2006 | 01:41 AM
dklau33's Avatar
Spring rates are done in kilograms per millimeter or pounds per inch. Do the math conversion. Off the top of my heads that's about 560 lbs/in. and 448 lbs./in.
Old Oct 6, 2006 | 12:18 PM
kenchan's Avatar
^^ that's pretty close for top of the head calc!
HypedAndy
Aug 18, 2015 03:34 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
