OEM Sway Bar brackets from 04 to 05 the same?
Old Oct 8, 2006 | 07:38 AM
aleok's Avatar
i thought i read the front sways on the 05 sports tuned suspension was thicker then the 03-04 sway bars? is this true? can you used 05 sports tuned brackets on an 03-04? need to know asap. thanks.
Old Oct 8, 2006 | 06:00 PM
aleok's Avatar
anyone know?
Old Oct 8, 2006 | 06:15 PM
636Racer's Avatar
dont matter. it's the inner diameter of the bushings that you should be concerned about.
Old Oct 8, 2006 | 06:23 PM
aleok's Avatar
well i found out that the bars diameter didn't change just the wall thickness. so the bars are the same size just has a thicker wall. 5mm to 7mm. so should be good right?
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
linedr89
Aug 17, 2015 05:11 PM
wuppiedog
Aug 7, 2015 11:16 AM
