My SPC A-Arm installation
Old Oct 13, 2006 | 11:49 PM
dvsmeth0dz's Avatar
very useful, thanks!
Old Oct 18, 2006 | 08:45 PM
aleok's Avatar
anyone can help me with installing the shim, those are kind of confussing me. not really sure where they go.
Old Oct 19, 2006 | 01:51 AM
aleok's Avatar
ok i tired installing just the arms. and it's been a disaster. the problem came when i was putting pressure on the rubber ball joint and the thing like "smashed" or "shrunched". but in the pic in the write up the rubber thing held up. is it suppose to smash? then as i'm trying to un-shrunch it the whole rubber thing comes off along with the gold ring that held in on the joint. and all the grease is everywhere. AND the red rubber thing now has a small rip in it. seriously wtf!
the thing shrunched
red thing off and ring off, and rip.
Old Oct 19, 2006 | 01:31 PM
IAPDirect.com's Avatar
Please contact me on this. The balljoint boot will "smush" up depending on the way you have it in. As for it going back on, it will definitely reinstall just fine. PM me if you have any questions.
Old Oct 19, 2006 | 02:16 PM
TwinTurboZ's Avatar
Installed mine yesterday. I had -3.4 R and -1-7L for camber; looks straight now. I will have it aligned today and post my results.
The only problem I ran into during my install was removing the black metal bushing from the oem a-arm. I went to autozone and borrowed one of their tools, came right off. I forget the name, but it looks like this one.
Old Oct 20, 2006 | 07:02 PM
Aznteazer's Avatar
any of you guys with the spacers installed have abs, vdc, and slip light on?
Old Oct 20, 2006 | 08:51 PM
aleok's Avatar
^ why? do you?
Old Oct 20, 2006 | 09:15 PM
Aznteazer's Avatar
not sure if its the camber kit, but those lights came on after the install.
edit:
shop told me to come back monday to have it checked out. i'll put up an update once everything is resolved.
other than that, my front camber looks awesome.
Old Oct 20, 2006 | 09:24 PM
SFLG35's Avatar
FGC President
you could have bumped on of the sensors on there which could cause the problem.
Old Oct 23, 2006 | 07:17 PM
aleok's Avatar
edit:
update?
Old Oct 23, 2006 | 09:51 PM
Aznteazer's Avatar
i've been getting no calls back from the shop.........hmmm......
im sure SFLG35 is right. whether the abs sensor was misplaced on the mount, or just mishandled, i don't think it's the camber kit that is causing this problem.
so, ultimately, IMO, the shop will have to pay for this fix, like it or not.
Old Oct 23, 2006 | 11:01 PM
aleok's Avatar
^ probably, i just installed one side (taking a break) and i tried as much as i could to avoid bumping the abs sensor around, hopefully it won't go off.
fyi- the situation with the red boot: i got the ring and everything back on with the help of peter? at IAPDirect, and i used 100% silicone around the whole thing, and its holding up fine. i feel like wrapping a condom over the boots, like some guys did with other camber kits. for added protection.
Old Oct 24, 2006 | 02:18 AM
mark4x4's Avatar
I had my alignment guy install my kit with the spacers and my light came on and he readjusted the sensor and everything was fine. He said when he torqued the sensor down that it got tweeked and he just straighten it and the light went out.
I had both front and rears camber kits installed and noticed that it raised the my car about .5". Did any of you notice this happening.
Old Oct 24, 2006 | 05:11 AM
aleok's Avatar
^ no i didn't notice that, how much are you dropped? after installing my front camber look very good, but my back is still has a LOT of neg. camber.
Old Oct 24, 2006 | 05:25 AM
  #30
mark4x4's Avatar
I'm dropped F/1" R/.6" and when I installed both camber kits it raised the fronts and the rears although it raised the rears more. The fronts raised about .25" and the rear raised about half an inch. I felt the front drop of 1" was perfect and being raised .25" it still looks OK, but the rears was not lowered enough to start with and now adding another .50", I'm back to stock height. I'm back to square one.......
