HKS RS Coilovers
HKS RS Coilovers
I've decided to upgrade my suspension from the D-spec/350Z S-tech combo to the HKS RS coilover. There is only one part #(80040-XN001) for both applications (G&Z). I know most 350Z springs drop the Coupe 1/2 inch on top of what's advertised. I got a total drop of 1.2 with the S-techs for the 350Z. Does the same apply for the HKS RS since there is only one type? I read that the minimum drop is .7", does this mean my total drop up front before height adjustment will be 1.2"? I know weight of the car and rate of spring has alot to do with how much the drop will be. Does the same apply for coilovers?
according to the hks hipermax rs manual you will be dropped -20mm from stock front and -10mm from stock rear with the default settings.
oops sorry, i thought it was the 350z forum heights changed.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
