Frankenstein Setup
Old Mar 24, 2007 | 12:05 PM
deuceduzit's Avatar
Frankenstein Setup
I currently have the un-revised 350z setup on my G35 04 sedan. I just bought some REVISED shocks (all 4) will these work w/ my unrevised springs? How will this effect my springs? Will this cause it to blow out? I know it has different springs rates.
Old Mar 24, 2007 | 05:05 PM
g35rcr's Avatar
they will work but it will cause the shocks to wear faster than normal since you are running it not within the original specs...
Old Mar 24, 2007 | 05:20 PM
deuceduzit's Avatar
Really? Why would it effect the shocks? The rear shocks support up to 427 & the unrevised rears spring rate is 342, wouldn't this take out the springs faster than the shocks? Shouldn't the shocks have no abuse?
Old Mar 25, 2007 | 12:46 AM
Gsedan35's Avatar
Totally 100% a non issue, zero to worry about, I recommend the change.
Front spring rates are the same for all years of oem 350Z springs. In the rear, the revised shocks are perfectly at home with the softer springs from the unrevised 350Z suspension (342 vs 427).
How things will be different. The shocks are softer then the one's your pulling out and this will translate into a softer overall feel. The pay off will be in much better ride control as in a lot less bounce and freeway porposing. Even though the car will feel softer, you'll be able to carry more speed around your favorite corner because of the better rebound control.
Old Mar 25, 2007 | 12:58 AM
deuceduzit's Avatar
Thanks for the reply bro, greatly appreciate the help your giving us newbies around here! =D Thanks bro.
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
AL8782
Oct 3, 2015 10:26 AM
JustinMKN1
Sep 18, 2015 03:40 PM
