wheel spacers..
Old Mar 27, 2007 | 02:16 AM
Fiveseven's Avatar
wheel spacers..
i know this has been discussed before.. but im looking for a updated advice since many of you are running wheel spacers now.. im about to trade my wheels for some other rims that will require me to run spacers in the front.. yes or no? do i need longer studs?? its a 2-3mm spacer.. any advice is helpful thanks!
Old Mar 28, 2007 | 12:22 AM
waijai's Avatar
i.love.gold
You shouldn't need longer studs with a 3mm spacer.
Old Mar 28, 2007 | 12:51 AM
papiloco21's Avatar
with only 2 or 3mm you should be fine
Old Mar 28, 2007 | 02:27 AM
cshih2's Avatar
if u want to go fast, spacer is NOT wut u want.
Old Mar 28, 2007 | 03:20 AM
redlude97's Avatar
based on....
Old Mar 28, 2007 | 06:56 AM
papiloco21's Avatar
....silly opinions
Old Mar 28, 2007 | 12:43 PM
sen_jen's Avatar
Meatshake Enterprise
^ no, you're correct in a way imo. if you get spacers that require longer studs, but choose not to add the studs..........that means u aint going fast!!!!!!
Old Mar 28, 2007 | 12:56 PM
maj83's Avatar
lazy a$$
wtf?
Old Mar 28, 2007 | 01:27 PM
redlude97's Avatar
We are talking 2-3mm here
Old Mar 28, 2007 | 04:42 PM
BadBoy06's Avatar
pubic hairs man..lol
Old Mar 29, 2007 | 05:22 PM
Fiveseven's Avatar
bump.. need to know :[
Old Mar 29, 2007 | 05:26 PM
Jeff92se's Avatar
Red Card Crew
Fasteners in general need xx amount of thread engagement in order to achieve the correct amount of clamping strength. I forget but I believe you need at LEAST 6-7 turns of the lug nut in order to get any type of safety(it's probably 2x that amount).
I've read too many stories about the 240sx crowd putting on huge spacers to get that drifto look. Only to lose a wheel around a corner and crash. Numnutz
Old Mar 30, 2007 | 02:28 PM
Jason@Riverside's Avatar
If you are going to do a spacer... IMHO its not worth it unless its 10mm or larger...
The Hubcentric spacers with Hubcentric wheel bore extension do not start till 10mm...
if you put on a cookie cutter spacer, your just asking for problems...
Old Mar 30, 2007 | 02:31 PM
Jeff92se's Avatar
Red Card Crew
Jason, if you want to suggest that great, but you should also advise people to use new/longer studs also. Just a thought
Old Mar 30, 2007 | 02:40 PM
redlude97's Avatar
I think he did by telling people to use 10mm or larger spacers since only those have extended studs
