Kics Spacer Installed!! (Pics)
Old Apr 3, 2007 | 08:33 PM
hji1945's Avatar
I installed Kics Spacer today.. 15mmF/20mmR..
Before:
After:
While I was installing it.. I found this little bolt on the rotor on the front.. And I just took them off cause I didn't know what to do.. Is that ok??
Anyway.. It looks great.. And now I think I need to drop my car really bad..
Old Apr 3, 2007 | 08:36 PM
redlude97's Avatar
Looks good to me, I woulda gone 25/30mm and rolled the rear. That bolt is also fine to remove, it just prevents the rear wheels from being put on the front
Old Apr 3, 2007 | 08:38 PM
Andy2434's Avatar
The addition of the spacers looks great. It really puts the wheels in a better line with the fenders. The bolt is merely a safety precaution so that the rear and front wheels are installed in their proper positions.
Old Apr 3, 2007 | 09:13 PM
hji1945's Avatar
Thanks Guys..!!!.. I was afraid to drive it... HAHA.. I guess now I can go out there and drive my car..
Old Apr 3, 2007 | 09:33 PM
Calvin's Avatar
Overglorified Altima
subtle, yet very necessary mod! looks much better!
Old Apr 3, 2007 | 09:49 PM
nikkaitsme's Avatar
is there any pros an con about using spacers?
Old Apr 3, 2007 | 10:18 PM
BlackOutG's Avatar
how much did you pay for those and where can i get them
Old Apr 3, 2007 | 10:23 PM
BlackOutG's Avatar
i really need to know which one you got
thanks a lot
Old Apr 3, 2007 | 10:29 PM
richie's Avatar
Yea, I was wondering the same... Obviously it'll widen the wheelbase but are there any downsides to adding a spacer?
Old Apr 3, 2007 | 10:37 PM
BlackOutG's Avatar
how man mm can i put with this rims on the G ?
thanks a lot and where can i get them
Old Apr 3, 2007 | 10:38 PM
redlude97's Avatar
about the only downsides to a properly installed spacer that is hubcentric is added wear on the wheel bearings, but no more than a low offset wheel would add so not really a big issue
Calvin's Avatar
personally, i would only run spacers on stock wheels. if youre getting aftermarket wheels, just get the right offset to begin with. some aftermarket wheels are only available in conservative offsets...so spacers would need to be applied then, too.
read up:
https://g35driver.com/forums/wheels-tires/52645-wheels-installed-using-spacers-good-bad.html
kenchan has some good info
Old Apr 3, 2007 | 10:39 PM
redlude97's Avatar
What are the offsets, tire sizes, drop, camber settings, and are you willing to roll your fenders?
Old Apr 3, 2007 | 10:40 PM
GLuXuRy's Avatar
what are your offsets ?? you can get project kics at mynismo.com
Old Apr 3, 2007 | 11:06 PM
BadBoy06's Avatar
spacers = love-love
