polished Circuit Sports strut bar
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
I received the strut bar about 1-2 weeks ago. Shipping was very quick, it only took one day. But I spent the past few days polishing it to match the crawford plenum, which I had polished previously.
Started with 80 grit flapwheel on the dremel to strip off the powdercoat. I have pics of the bar as it arrived, but I think we all know what the stock CS bar looks like.
I then moved onto a 120 grit flapwheel, then some hand sanding with 320 grit paper (the only wet paper I had), then the usual polishing wheels with a rotary drill.
I had to take off my 1/4" spacer. I also had to grind down the head on the front bolt on the plenum to create clearance.
I haven't had a chance to drive that much, so I can't give a driving impression yet.
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
