Sway Bars 07 Sedan ????
Old Apr 14, 2007 | 11:18 PM
dplatow1's Avatar
Any suggestions about the best sway bars to use on an 07 G35??
Do they cancel out any warrenty coverage???
Are they worth the investment???
Old Apr 15, 2007 | 01:31 AM
DarkG's Avatar
yes.. their great.. any aftermarket sway set is great.. there not very $$expensive.. soo its def a mod to get.. prolly my favorite.. NIght and Day differenece!
no they don't void the warrenty....
best mod to get personally...
"say goodbye to body roll"
Old Apr 15, 2007 | 01:48 AM
terrycs's Avatar
Sway bars should not affect your waranty. I'd say the ROI on a Sport is very little because the sport already comes with some beefy sway bars. You can see the black colored rear bar under the differential:
If you have a Journey, you may want to consider it.
Also note an aftermarket bar for an 06 will not fit an 07.
Old Apr 15, 2007 | 08:02 AM
chuckg35's Avatar
I can't imagine that aftermarket sway bars would improve an S- there is little lean and no slop under hard cornering just as it is set up stock.
Old Apr 15, 2007 | 11:05 AM
terrycs's Avatar
Wait till you see how it handles after it lowered!
Old Apr 15, 2007 | 01:19 PM
Audiophile's Avatar
Has anyone measured the diameter of the sport? I measured the journey a while back and it was only 15mm, a 20-22mm bar is the answer for the rear of the non-sport cars. I don't think the front will need replacement because it is +/-25mm already
Old Apr 15, 2007 | 01:31 PM
terrycs's Avatar
I haven't actally measured it, but I've been under the car several times and it looks to be about 1" (25mm), maybe slightly more.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
