"Brake" light on after BBK install
Old Feb 10, 2008 | 04:45 PM
G35sedan03's Avatar
thanks for the answer.
Old Feb 12, 2008 | 12:18 AM
n1cK's Avatar
G35 6MT
Originally Posted by ttrank
Yeah that is what I am getting. If you hear that the springs come out please let me know!
ap racing has pad knockback springs, though unless you do track the car often, there may be no need to get them. but to each his own...
Old Feb 12, 2008 | 12:39 AM
ttrank's Avatar
Grocery getter
Thank you but those are only for the AP kits. I will need one for Rotora's.
Old Feb 12, 2008 | 04:14 PM
n1cK's Avatar
G35 6MT
tim, i believe the ones listed in the apracing website are universal. the kits they offer are specific, but the springs in the upper table are universal.
Old Feb 12, 2008 | 04:41 PM
ttrank's Avatar
Grocery getter
Oh ok. I'll go back and look again.
Old Feb 12, 2008 | 11:27 PM
Gilley's Avatar
Loren didn't call you about them? They should be available in March/April.
Old Feb 12, 2008 | 11:30 PM
ttrank's Avatar
Grocery getter
No I didn't hear anything. Let me know when they tell you!
Old Feb 12, 2008 | 11:48 PM
Gilley's Avatar
Loren called me the other day. He said the springs would be available March/april. You will need to disassemble the calipers and install the springs and new pistons. Pad wear will be accelerated because the springs will force that pads into constant contact with the rotor.
Two springs will be available. One for street and the other for track.
They also have new rotor pins available if you want your rotors to be more free floating. Some people have noticed a vibration when braking hard and these pins will fix that. I don't have that issue though.
Also, race compound pads are now available for the 12 piston calipers and will be available for the 8 piston calipers soon.
Old Feb 13, 2008 | 12:20 AM
n1cK's Avatar
G35 6MT
Originally Posted by superchargedg
how did you bleed the brakes,it should be r/r,l/r,r/f,l/f...the metering valve might not have reset to its correct position.how does the pedal feel.
from the FSM (pg BR-10) it should be rear right, left front, left rear, and then right front.
ttrank's Avatar
Grocery getter
Wow Sean you got all the info!!
I didn't deal with Loren so that may be why. I think I could deal with the pads wearing out a little faster for a better response. I assume Rotora is the only place I can get pads?
Race pads would be sweet for track days but I will need to find some 19" race tires that can help or the better pads would just be a waste!
If you don't mind can you let me know when they tell you the springs are available?
Old Feb 13, 2008 | 07:38 AM
Gilley's Avatar
Of course.
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
attarday
Jul 15, 2015 04:03 PM
