350z spring color dot ?
Old Apr 16, 2007 | 06:20 PM
bios2k's Avatar
Hi, Im about to buy a custom kit for my 2003 G35 Sedan with sport Shock.
Im looking on the fron 350z springs and rear coupe spring.
what is the color dot I need, I've read 2 post and each is different.
1pink = front and the other say 1 white 2 red = front
and for the coupe spring.
what color I need for the rear.
Can some one explain exactly what I need !?
thks
Old Apr 16, 2007 | 07:43 PM
jameyb's Avatar
If you want to keep your stocks shocks and install rear coupe springs with the lower spring rate (342), you need to get rear springs from a coupe that does not have 19" wheels. If I remember correctly, the coupe springs you want have 3 red dots (these are the same springs I have). I am not positive, however, so just make sure you get them from a coupe that does NOT have OEM 19's.
As for the fronts, it doesn't matter, just get any set of Z springs. The front spring rate is the same for all Z's, coupes, and sedans (03-06). The spring rate is 314.
Old Apr 17, 2007 | 08:44 PM
bios2k's Avatar
Thank You for the Info!!
Old Apr 18, 2007 | 12:45 AM
jameyb's Avatar
Anytime, good luck on the install. If you are doing the work yourself here is a really good DIY:
https://g35driver.com/forums/showthr...ghlight=spring
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
linedr89
Aug 17, 2015 05:11 PM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
Duriisimo
Jul 31, 2015 02:21 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
