rotors?
Old May 2, 2007 | 02:16 PM
04Gwhiz's Avatar
rotors?
i have an 04 coupe...I have stock brembos..thinking about changing the rotors front and back..leaning towards drilled..where can I get the best price for front and rear? what brands should I be looking at?(R1, brembo, rotora etc...)all help is appreciated in advance
Old May 2, 2007 | 05:33 PM
myDOORSgoUP's Avatar
i have brembo drilled rotors, but havent put any miles on the car since installing....once its painted ill know how well they work but fyi i did steel braided brake lines in mine and the pedal feels really nice...gives more feedback....
Old May 2, 2007 | 05:38 PM
filanj's Avatar
Stick to name brand. Don't get some cheapo EBay rotor set because you get what you pay for. Infusion G35 has a group buy sale going right now for REALLY good prices on full sets. Slotted and Drilled. I haven't made up my mind yet, but I'll most def be going with the slotted... I've heard too many bad stories about drilled rotors cracking and warping and so forth.
Here is a link to his thread. I'm not sure whether you'll be able to see it or not if you're not a premier member though. https://g35driver.com/forums/brakes-vendor/118646-brembo-rotors-fully-stocked-ready-go.html
Tell him I sent you
Old May 2, 2007 | 05:48 PM
ttrank's Avatar
Grocery getter
+1 on the name brand. You may be tempted to spend 1/2 on the cheap ones but you will regret it.
Old May 2, 2007 | 05:50 PM
filanj's Avatar
Exactly... Just look at the long threads on the R1 rotors with all the complaints and so forth... do it correctly the first time, so you won't regret it later on.
Old May 2, 2007 | 06:14 PM
03 6MT's Avatar
I just bought the Brembo drilled via the group buy. Price seemed reasonable,the rotors look amazing. I'll be installing them next week. From my understanding drilled and slotted are OK as long as they are manufactured that way and not done aftermarket. Word of warning, Brembo does not make a combination drilled/slotted rotor. These look hot but are done aftermarket.
Old May 2, 2007 | 11:05 PM
Gilley's Avatar
With the Brembo rotors, you have the option of one-piece and two- pice rotors. It depends on what you want.
Old May 3, 2007 | 07:08 PM
Kidcane's Avatar
I think the Brembos are typically a little more expensive than Rotora which are really just as good.
Old May 5, 2007 | 11:31 AM
hotsand5's Avatar
per Tire Rack's recommendations...Drilled rotors are not intended for track use, use solid or slotted rotors for track purposes.
If you are just using the drilled for looks and on the street/ autocross, then you should be fine.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
