Lowering or no Lowering??
Old May 22, 2007 | 09:42 PM
jww's Avatar
jww
I just got some 19inch wheels replaced the 20's I had, damn i should got 20s again.. now i have a 1 inch gap now between my tires and my fender...it looks ugly! Should I lower it?! I need u guys' advice.
Old May 22, 2007 | 09:53 PM
izmir41500's Avatar
G35driver Addict
yes. why would anyone on here tell you not to.
Old May 22, 2007 | 09:58 PM
Gam3's Avatar
yes definitely lower!
Old May 22, 2007 | 10:20 PM
Beebo's Avatar
well yeah lower!
i cant because i bottom out all the time and scrape the bottom of the bumper at stock
Old May 23, 2007 | 12:32 AM
g35philong's Avatar
Lower your car, you can go with a less aggressive drop such as 1.2 in the fronts and .9 in the rears, it should make your 19's look good.
Old May 23, 2007 | 10:22 AM
GreenGoblin's Avatar
The goblin resurrection
I lower then needed to go lower so went with coils
Old May 23, 2007 | 10:38 AM
SFLG35's Avatar
FGC President
slam it
Old May 23, 2007 | 10:42 AM
Cost a G's Avatar
Originally Posted by SFLG35
slam it
^^ Exactly
Old May 23, 2007 | 11:49 AM
Jtrain's Avatar
Thats a pretty serious Drop.
I have some Htech's in my garage, I just can't pull the trigger tho.
Old May 23, 2007 | 12:26 PM
CHIZELD's Avatar
Love Poker!!!
I have my stock oem 19's w/a 1in drop in the front and a .6 drop in the rear. I have swift springs and my front is always scraping. I didn't think one inch drop in the front would be so or seem so low. but now i don't have a gap in the front and my rear is perfect. Went with Swift springs because it's a better quality spring then tein or most of the other brands out there.
Old May 24, 2007 | 04:00 PM
MIAG35's Avatar
I say put some King shocks with the rezzies on it and lift that motherf@cker!! Donk style!
Old May 25, 2007 | 05:20 AM
by15vc's Avatar
get bags!
Old May 25, 2007 | 07:31 AM
Mark350GT's Avatar
definately lower it with some coilovers
Old May 25, 2007 | 09:35 AM
ron4row2's Avatar
I would definately lower it.
Old May 26, 2007 | 01:06 AM
terrycs's Avatar
You sure you got the right aspect ratio tires to match the stock ones? There shouldn't be much difference in tire OD between stock, 19" and 20" if the tires are sized right.
