Will Brembo coupe brakes fit an 03 sedan?
Old May 25, 2007 | 08:25 PM
maliy06's Avatar
I found some Brembo coupe brakes. Will they fit my 03 sedan?
Old May 25, 2007 | 08:49 PM
qbturbo's Avatar
Do a search Paul. I believe hksjza70 has this set up on his 2003 sedan. Requires the right offset or spacers.
Old May 25, 2007 | 09:32 PM
nghiars's Avatar
yea they will as far as bolting on... you will need to get new dust shields to fit around or you can cut yours... i think they are just a few dollars for new ones... and of course you should know you will have to find wheels that clear them
Old May 25, 2007 | 09:44 PM
maliy06's Avatar
How about the brake lines, and will coupe's 18" stock wheels will be good?
Old May 26, 2007 | 09:30 AM
TIRE_SMOKE96's Avatar
wait so does this mean that the brembo setup will give the sedan a coupe offset, so I can use coupe wheels?
Old May 26, 2007 | 11:42 AM
slowsocalg35's Avatar
I installed the Brembos (OEM calipers, rotors, pads) off a 2004 Coupe onto my 2003.5 Sedan. You need new rear caliper bolts as the stock bolts are little too short for the Brembo calipers. I went ahead and bought new caliper bolts for both the front and rear. While everything was off, I had stainless steel brake lines installed. I don’t know if you can reuse the existing brake lines or not, but the cost of the brake lines is small compared to the calipers and rotors. You will also need to cut the stock dust shield around the rear rotors to accommodate the larger Brembo rotors. If money is no object, you can have the dust shields removed and install the dust shields off the Coupe. But this involves removing the rear hubs which I’ve heard can be tricky. You won’t be able to reuse the stock wheels or spare tire from your 2003 Sedan as there isn’t enough clearance to get around the larger Brembo calipers. I bought a set of 6mt Coupe 18 inch wheels, and the 6mt spare tire. With the OEM 2003.5 brakes, I was going through pads like crazy and the dealers was changing or resurfacing my rotors all the time. The Brembos have been great!! If anything the Brembos are over engineered for the car. This is a good investment if you are going to keep the car past the 3 year/36k mile brake warranty Infiniti gave on the 2003 Sedans. The cost of ownership skyrockets if you need to install new pads and rotors all the time. I was able to order the bolts and the brake lines from performance nissan parts. I had a shop install the Brembos for $250 – I supplied all the parts. Good luck.
Old May 26, 2007 | 02:02 PM
maliy06's Avatar
Thanks for the info "slowsocalg35"
Old May 26, 2007 | 02:41 PM
ttrank's Avatar
Grocery getter
The oem brembo upgrade is an awesome choice but they are not cheap on here!
Old May 26, 2007 | 02:54 PM
bull3t's Avatar
i love my brembo's...the oem brembo pads lasted me until 36k miles...
Old May 26, 2007 | 04:11 PM
maliy06's Avatar
Do you guys thing its a good deal if two rear used Brembo caliper for $200. The calipers are from a burned car. But you could see the suspension was not burned
Old May 26, 2007 | 04:20 PM
Nismo G's Avatar
No, adding a big brake kit will not change the offset of the car.
-Sean
Old May 26, 2007 | 08:52 PM
ILLicit's Avatar
Hell yea thats a sick deal.
Old May 27, 2007 | 04:44 AM
ttrank's Avatar
Grocery getter
Make sure and get the brackets too.
Old May 29, 2007 | 10:35 PM
maliy06's Avatar
Yeah i will,
maliy06's Avatar
will only need to find some front ones too.
