aftermarket shocks for g35X?
Old Jun 26, 2007 | 06:32 PM
FutureGDriver's Avatar
I have a 2004 g35X sedan with 2003 Tein S-techs springs on my factory shocks. ride is ok and not bouncy but stiff on the rear. Is there any aftermarket shocks i can put on my car?
Old Jun 26, 2007 | 11:39 PM
Gsedan35's Avatar
That odd, G35 S-tech rear springs are softer then the oem springs you took out. You can install any rear shock ment for the RWD G or Z. The only thing is the shock you should use to get softer dampning isn't sold as rear's only. Tokico D-specs to my knowledge are only sold as a front and rear set. Call Tokico's tech line and ask them if they would sell just rear's. If they will you'll just need to find a reseller that authorized to sell Tokico and have them place the order. I would try Performance Nissan or www.mynismo.com . I don't see Koni's being the answer. Though we do have on G35X owner that is running Bilstien's in the rear. Note sure the Bilstein's fixed dampning will be softer they your oem setup or as soft as D-specs that are adjusted lower.
Hope that helps.
jilljann1
Jul 21, 2020 08:12 AM
Albanian122
Sep 7, 2015 07:41 PM
kevintandmd
Sep 3, 2015 06:41 PM
TheBay
Sep 3, 2015 03:27 PM
