2006 G35 Coupe MT: Alignment Specs
Old Jul 2, 2007 | 07:51 PM
yakkolio's Avatar
Posting my alignment because Firestone thinks I've been in a car accident. They couldn't adjust the front camber so they felt that since it was in the red the car hit something really hard. Is my alignment good? Thank you for any input.
Front LEFT
Camber: -1.16
Caster: 7.89
Toe: 0.06
Front RIGHT
Camber: -1.19
Caster: 8.22
Toe: 0.07
Rear LEFT
Camber: -1.06
Toe: 0.03
Rear Right
Camber: -1.57
Toe: 0.09
Old Jul 3, 2007 | 12:09 AM
yakkolio's Avatar
bump
Old Jul 3, 2007 | 12:16 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
lol, what firestone did you take it to? Your alignment is good, if your car is lowered that's why its in the red. Still, -1.1 is perfect camber for the front, i wish i could get mine that positive.
-GP-
Old Jul 4, 2007 | 02:56 PM
yakkolio's Avatar
No my car isn't lowered, it was because the firestone guy was telling me that my might have been in an accident because of the negative camber
Old Jul 4, 2007 | 02:58 PM
99.9% of cars these days come with negative camber from the factory. It is completely normal you are still well within factory spec.
-GP-
Old Jul 4, 2007 | 05:33 PM
redlude97's Avatar
Have them adjust the rear right to match the rear left though, they are off by too much IMO, or if there isn't enough room for adjustment, increase the camber and toe on the left side to match the left side
Old Jul 4, 2007 | 08:47 PM
bocatrip's Avatar
Camber can be affected as easily as going through an automatic car wash. I like your front toe specs especially. Try to keep them as close to .08 as possible. That will help to slow down the front feathering. My tech for some reason has .05 as the max toe spec for the front which is wrong. In addition, after I had the compression rod TSB done my caster on the right side is out of spec at 9.56. Your specs look good!
arora_g35
Apr 16, 2026 02:52 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
BlackGee35
Jul 23, 2015 01:36 PM
ResoG35Sedan
Jul 14, 2015 10:30 AM
