A few suspension/handling tips (found on datsuns.com)
Old Jul 8, 2007 | 02:05 PM
rcdash's Avatar
Thumbs up A few suspension/handling tips (found on datsuns.com)
These all look correct to me. Enjoy!
HTML Code:
If your car understeers		If you car oversteers
Softer front springs		Stiffer front springs
Smaller front anti-sway bar	Bigger front anti-sway bar
Decrease front negative camber	Increase front negative camber
Less front tire pressure	More front tire pressure
Wider front tires		Narrower front tires
Decrease front weight bias	Increase front weight bias
Increase rear negative camber	Decrease rear negative camber
Stiffer rear springs		Softer rear springs
Increase rear tire pressure	Less rear tire pressure
Bigger rear anti-sway bar	Smaller rear anti-sway bar
Narrower rear tires		Wider rear tires
Increase rear weight bias	Decrease rear weight bias
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
danielidiaz13
Engine - Exhaust
Sep 22, 2015 02:57 PM
TeamNoSleep
Sep 13, 2015 07:40 PM
