Are D-specs same length as OEM shocks?
Old Jul 10, 2007 | 12:03 PM
kevmi2ca's Avatar
I'm trying to figure out why my car sits a little lower and rides like crap (lot more bumpsteer) after installing D-specs 7's.
Car drove great with eibachs and oem shocks.
Thanks.
Old Jul 10, 2007 | 01:01 PM
Triple8Sol's Avatar
DSP-7 is the same height. DSP-9 is slightly shorter in the rear. I went with the latter, since it makes much more sense with lowering springs. No issues at all when I had that setup.
Old Jul 10, 2007 | 01:17 PM
savefatkids's Avatar
Thanks.
i got the same shocks. you probably got the 350z version which is a little shorter. as for ur ride being rough, thats completely normal. whats ur dampening set at? if you have it all the way stiff. try moving down 3 turns and it makes a huge difference. thats what i do on long trips
Old Jul 10, 2007 | 02:51 PM
Q45tech's Avatar
Bump steer is a result of lowering where the tie rod angle is changed fom oem position.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
Dundermuffin666
Aug 14, 2015 04:01 PM
smartin0924
Aug 13, 2015 07:29 PM
