Richie STrut Bar Install HELP!
Old Jul 18, 2007 | 07:07 AM
kaloman's Avatar
i need some help. for some reason the strut bar installation was a disaster. everything went well until the installation of the actual bar. it almost seemed to tough to position the bar to line up the holes. i had to use a wrench to lever the bar into place.
after tightening the allen wrench bolts, everything looked good and i was pondering over the amount of space between the plenum (without cover. i also have a 5/16 md spacer), which seemed to be a lot. so i attempt to slowly lower the hood and it looked good until trying to lock the hood down, it appeared tough to do, there ended up being a bulge on each side of the hood. so i was like damn... the bolts weren't all the way down.
so i tried to unloosen the bolts and reposition the bar, which i couldn't get down anymore. i next wanted to remove the bar entirely, leave the brackets and think about elongating the mounting holes later. i got one nut off of the driver's side bolt then i tried to get the passenger's side loose. no luck.
there was so much tension/compression on the mounting points from the bar that the passenger side bolt bound and as of right now i cannot remove the nut from the bolt. it's definitely threaded beyond belief. i used an 8 inch long wrench and a pretty long allen wrench and it wouldn't budge. i basically now need to cut the bolt with a hand saw but that'll be tough also because there is hardly any room with the washer and lock washer. the bar is just sitting in my engine compartment loose.
richie, i need to get a couple of new bolt/washer/lock washer/nut combos. basically two more. the driver side bolt also got a little threaded while backing the nut out. also any advise to this problem? i followed the instructions exactly.
what should have taken no more than half an hour ended up being 2 hours and still no completion. anyone else had this much trouble with the installation? i'm in need of some advise. i was soooo excited to install this tonight and take a test drive.
so sad...
Old Jul 18, 2007 | 11:13 AM
imalazeeass's Avatar
dont give up man things happen all the time.
Old Jul 18, 2007 | 01:53 PM
richie's Avatar
Kaloman,
Check your PM. Sorry for all the trouble but we'll get you all setup and running shortly.
Remember there are always little bugs/fixes when it comes to modding.
- Richie
Old Jul 18, 2007 | 01:59 PM
izmir41500's Avatar
G35driver Addict
the strut bar should be in the lowest position. i had to pry the bar into the bracket with a wrench but that was it. good luck.
Old Jul 18, 2007 | 02:04 PM
Hexxum001's Avatar
Don't worry bro, Richie will take care of you.
Old Jul 19, 2007 | 03:37 AM
kaloman's Avatar
yup, Richie pm'd me right away. i'm very satisfied with shipping and customer service. i'm also very excited that many have been extremely satisfied with this product! i can't wait to jump on the bandwagon!
jsimonk
Dec 22, 2023 03:49 PM
North NJ G
Steering & Suspension
12
May 27, 2023 01:14 AM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
syxth_element
Aug 18, 2015 07:16 AM
linedr89
Aug 17, 2015 05:11 PM
