Nismo suspension bushings
Anybody instally anything like the following:
http://www.mynismo.com/products/?id=5348
Would these nismo bushings really make much of a difference---I imagine install would involve a lot of work. Any input?
i replaced a pair only because i got the suspension piece powdercoated.
the nismo bushing is just a harder rubber.
you're not going to be able to tell much difference, especially since our cars are still new, the OEM bushings prolly haven't worn down yet.
i had a dealer install mine.
I did the poly bushings on my talon and let me tell you bro. NOT EASY. The kits are always cheap. Somewhere between 150 to 275 for a full kit. However what they dont tell you is that it takes about 600 bucks in labor to swap them. Then there is the fact that some parts might get bent upon install. And after all that with the poly unless they have zerck fittings for grease they squeek like the car is about to fall apart. I actually bought a press for 350 and installed the bushings on 2 other cars and made my money back for the press. good luck bro mike
