Anyone running 35-series on 20" Front?
Old Aug 2, 2007 | 07:45 PM
Gilley's Avatar
I first had 255/35/20 Nitto 555's on fron and hated them because they looked like a truck tire. They were actually a larger diameter than the 285/30/20 Nitto's I had on the rear.
Old Aug 3, 2007 | 09:38 AM
DTG's Avatar
DTG
What size front are you running now?
Old Aug 3, 2007 | 09:43 AM
617G's Avatar
CFW (Carbon Fiber Whore)
I'm running a 245/35/20 and 285/30/20 Falken 451
Fronts are 20x9 +23 I think...ask Gilley, he has the same wheels. I could def use like a 5mm spacer in the front, but it's good enough as is.
I have no rubbing issues at all, lowered on S-techs. But, I'm ditching them for 350z H-techs and Tokico's
Old Aug 3, 2007 | 10:06 AM
Gilley's Avatar
BFG KDW2's in 255/30/20 and 285/30/20. The KDW 285's are wider than the Nitto 555 285's.
The offset on the front Maya GR5's are +26.
Old Aug 3, 2007 | 01:02 PM
DTG's Avatar
DTG
What suspension? Finally, did you rub when you ran the 35-series tires on the front?
Old Aug 3, 2007 | 01:36 PM
Gilley's Avatar
Tein 350Z S-Techs, Tokico Spec D shocks, and SPC front a-arms and rear camber arms.
I never drove with the 35's up front because I hated the look. I don't think they would rub.
Old Aug 3, 2007 | 11:20 PM
617G's Avatar
Sorry, I ****ed up...I'm running a 255/35/20 up front. I have no rubbing issues and I have the SPC arms installed with the correct camber settings.
Old Aug 3, 2007 | 11:40 PM
izmir41500's Avatar
G35driver Addict
I'm runnin 245/35/20 in the front and 275/30/20.
My wheels are 20x9+15 and 20x10+20
stock sport suspension and no rubbing at all. i'm also in Dallas. streets do suck in some areas, but you should be alright if you lower on G H-techs or S-techs.
Old Aug 4, 2007 | 04:13 AM
Dan_K's Avatar
You can't roll the front fenders, they are already prerolled in stock form, just go look for yourself. Rubbing is highly dependant on offset as well as width, without knowing that, we can't tell you if its going to rub or not
So what happens if you get rubbing in the front? Is your only option to run more negative camber?
Old Aug 4, 2007 | 04:29 AM
Calvin's Avatar
Overglorified Altima
very few people that have that aggressive of an offset or running that large of a tire (andrew was running 265/35 on his fronts) are low enough to have to even worry about this. i can only imagine that they have to run negative 3+ camber.
Old Aug 4, 2007 | 04:38 AM
v3n0m's Avatar
255/35/20 on the front on an 06 6MT stock suspension.
+25 offset. Pirelli PZero's.
Stock suspension?
What size/offset front wheels?
What brand/model tires?
Old Aug 4, 2007 | 10:36 AM
sugsss's Avatar
My front I have a 20x9.5 +4 with a 225/35 20 so far its ok no camber kit and slight rubbing at full lock,search 20" vs-kf's .
Old Aug 8, 2007 | 01:15 AM
MEXDUX's Avatar
Im on stock susp. 245/40/20 front 275/35/20 rear. i know 40 is huge, i wasnt planning to lower my car any time soon and i drive it to much thru the streets and freeways of LA. i bitched out on the 30's cuz i heard to many stories on bending rims. i waited to long for my Volks to *** them up. anyways.. no rubbing at all in the front but a bit in the rear whne the tires were new but its kool now. My Volks will be for sale in the very near future.. GT7 in gold. pics coming soon...
Old Aug 11, 2007 | 12:50 AM
accordfreak's Avatar
i'm running 255/35/20 in the front. I also don't like it. looks a bit buldged. running about 1.3-1.4 degree camber .. the tires are slightly tucked. I'm only rubbing on the passenger side because the caster is jacked up some how so the wheel is closer towards the front. Driver's side i have no problems rubbing. I have a problem with both sides going up and down the driveway if I don't keep the wheels straight.
i'm going with 255.30.20 next time around.
Old Aug 11, 2007 | 01:00 AM
  #30
amazing35's Avatar
im running 255/30 in the front and they are very close to rubbing when the shock is fully extended. like when you are jacking up your car to change the tires.
rezendvous420
May 31, 2020 01:26 PM
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
realtalk21
Jul 20, 2015 09:07 AM
