Tokico D-specs with HKS coil adjsuters???
It is posible to install front HKS coil springs sleeves into Tokico D-spec???
The history:
I buy from guy here a set of HKS Ls+ coilovers that result to be completely broken. Right now im in the process to resolve this issue. But nevermind this.
The fact is that i have the Tokicos D-specs with Teins S working perfectly but i go with 20" rims with a very agreesive offset so i need to rise the car. I dont want to go for Teins H because i dont want to take the risk because i want a full 1" rise, higher than the Teins S. I have the coil sleeves of the front and rear HKS coil overs, i already keep installed the rear HKS springs with the adjusters and with the Tokicos with no problem, but i need to know if i can do the same with the fronts. Any help will be apreciated.
The history:
