Need help fast!
Ive done a lot of searching throughout the forum and I cant seem to find a definitive answer for my question. My brake pads are in serious need of replacement, and I have been looking at the Project Mu pads. However, I would also like to replace my rotors at the same time, all while keeping the stock calipers. Can anyone point me in the right direction for pad/rotor replacement for an 05 6MT with stock calipers?
Thanks in advance.
Thanks in advance.
Jason@RiversideInfiniti (look him up on the forums. Best prices on the web for G parts). You can keep your stock calipers when replacing your rotors. Just make sure you specify what type of rotors you need (ie Brembos or Non Brembo).
It all depends bro. What are you wanting to do? Do you want stock rotors or cross drilled/slotted? Also Jason has the best price on pads by far. I got mine from him and got them next day air! I called the dealer here and they wanted almost 900.00 to do my brakes. I spent under 150.00 for the pads and did them mysel. I didn't have to turn my rotors though.
Also Mike if you aren't busy feel free to stop in at this
https://g35driver.com/forums/showthre...12#post2177812
Well I would like to get new slotted/drilled rotors with the stock calipers. Either that or find some used brembos and install them myself. That is a little more expensive then what I wanted to spend though.
magnetism80
Jan 27, 2016 12:57 PM
