TPMS malfunction?? (!)
Old Aug 6, 2007 | 10:33 PM
DrewTheSuit's Avatar
i just started having the low tire pressure warning light appear on startup...turn the car on and it begins to flash about 60 times, then stays lit...i'm still on stock 19s and the pressure is correct for all 4 tires, so i check the owner's manual and come across the TPMS malfunction ( flashing sign then stays illuminated)...anyone experience this? any insight what might cause this, for example i'm over due on a scheduled maintainance not sure if it's a coincidence or not
Old Aug 6, 2007 | 11:37 PM
Memphoman's Avatar
coincidence I think, could be a malfunctioning BCM, or, even sensors need registering again, probably something that the dealer should handle for U. Seems thats lots of problems lead directly to the BCM.
*I am changing wheels and dealer is going to do the work and reregister the sensors when new wheels installed.
Old Aug 8, 2007 | 02:45 PM
lamypie's Avatar
Tpms
This system is more sensitive than the female gender. One lb. off in one wheel will set off the alarm. If you check tire pressure more frequent,like every week, you will not have the problem.
I found 38lb. is a good start.
Old Aug 8, 2007 | 02:54 PM
Memphoman's Avatar
his key malfunction is the fact that it flashes 60 or so times then remains on. SM clearly indcates that as a system problem rather than a low tire.
Old Aug 8, 2007 | 08:41 PM
agreed, i know it's not a low psi reading in any of the tires...looks i'll be spending my day off tomorrow at the stealership
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
Frankieg35
Sep 9, 2015 12:17 AM
