350z suspension on 03 sedan
Hi folks.
I have an 03 sedan (built in 02, one of the first models with the trunk that has no release), with stock 17inch wheels and suspension (non sport).I have been reading around here for about an hour, and from what I've read the best cost effective option to replace my current suspension (which is squealing in the back) and get a drop that won't affect ride quality or tire wear too much all while improving handling a bit is to replace all 4 springs and struts with 350z springs and struts? If I understand correctly, that will give me a drop of an inch in the rear and front? If so, what year of 350z springs and struts should I be looking for?
On a side note, also if I understand correctly, if I were to put coupe springs and struts on my sedan the front and rear would drop by half an inch?
Did I read the info right? Any info/help greatly appreciated!
You would need the suspension off an '05+ 350z. And yes, using coupe springs in the rear will drop the rear .5" which will make the drop look even since the rear fender is cut lower.
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
