How do I adjust ride height with teins Coil overs?
Old Aug 13, 2007 | 10:12 AM
denverinfiniti's Avatar
How do I adjust rear ride height with teins Coil overs?
TITLE SHOULD SAY REAR OOPS
Just installed a set of tein mono flex coil overs with EDFC over the weekend. I set everything per teins paper work. The car rides amazing and the EDFC is awesome! The owner will be leaving the car at the height I have it. But I'm just curious how you actually adjust ride height in the rear. I think its the spring my buddy thinks its the shock like the front. That just doesnt seem right to me. Can someone clear this up for me THANKS
Old Aug 13, 2007 | 11:04 AM
Gsedan35's Avatar
You adjust rear height buy adjusting the rear spring seat or spanner as some will call it up or down.
Since the Mono flex has full height adjustablity that allow's you to adjust the length of the dampners, you will also adjust the length of the rear dampners so that you are maintaining proper piston stoke. Buy also adjusting the length of the rear dampners your also keeping the sam average rear spring preload applied.
Of course this is different from the front where you adjust height by changing the length of the dampners only. You do NOT adjust front height by the springs since you only want to apply enough preload to keep the springs seated when the suspension is unladen (or the weight of the car is not on the suspension).
Old Aug 13, 2007 | 11:10 AM
Ok THANKS thats what I thought. The fronts are easy to figure out. The rears just a little decieving
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Brodys_GCoupe
Nov 7, 2015 08:06 PM
HypedAndy
Aug 18, 2015 03:34 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
