hks coilovers
Old Dec 3, 2007 | 12:26 AM
  #31
spooze's Avatar
how do you remove the lock collors. are you dumped in the rear? pics
Old Dec 3, 2007 | 12:31 AM
  #32
spooze's Avatar
i dont think a quarter inch will do it for me.
im considering selling my coilovers.
Old Dec 3, 2007 | 12:34 AM
  #33
k67p67's Avatar
I've got mine as low as it will go in the rear. To remove the lock collars, remove the springs and spin both collars down until they come off. Then, just replace the perch collar and spin it all the way up until it stops. Reinstall springs.
Old Dec 4, 2007 | 01:02 AM
  #34
spooze's Avatar
will it be safe. does it look lower than mine?
Old Dec 4, 2007 | 01:40 AM
  #35
k67p67's Avatar
Seems perfectly safe. I'd think the spring might move around a bit if you got rid of both collars. My wheel well gap is less than yours although I have 20s now and your JPs are 19s.
Old Dec 4, 2007 | 04:30 PM
  #36
spooze's Avatar
what part do i remove
Old Dec 4, 2007 | 04:41 PM
  #37
rookie's Avatar
The rear is different from those pics.
Here's on my FX. Not exactly the same but should be close to what you'll see under there. The 2 gold collars are the things to adjust height. The top one locks the bottom one in place. Take out the top one entirely, have the spring sit on the bottom one, have it threaded all the way up when you put the suspension back together.
Old Dec 4, 2007 | 10:56 PM
  #38
spooze's Avatar
looks like another quarter to half an inch. is it perfectly safe. thanks for the help rookie
Old Dec 4, 2007 | 11:10 PM
  #39
k67p67's Avatar
The collars on the HKS Hipermax RS coilovers for the G35 are 0.25" high. The ones on rookie's set up look thicker. I can't see how removing the lock collar would make it unsafe. The lock collar is just to keep the other collar from spinning upward.
Old Dec 5, 2007 | 12:15 AM
  #40
spooze's Avatar
i think going through the trouble of removing the collar might not be worth it. i called hks and they said i could change the spring but it would void warranty because the shocks might bottom out.
Old Dec 6, 2007 | 08:16 PM
  #41
spooze's Avatar
i might remove both collars. do you guys see anything wrong with that.
Old Dec 6, 2007 | 08:23 PM
  #42
rookie's Avatar
I think that's a bad idea. The collar the spring is in contact with is a good fit. The threads will be a looser fit. I'm not sure if the spring could pop out since it's held in place with the suspension but it might make for some noisy suspension.
If it doesn't go low enough you're better off putting in different springs and using the HKS shock as a better shock vs stock.
Old Dec 6, 2007 | 09:24 PM
  #43
k67p67's Avatar
Bad idea.
Old Dec 7, 2007 | 12:27 AM
  #44
spooze's Avatar
if i take the collars out wouldnt it be like puttin in a drop spring. cause drop springs dont have collars right?
Old Jan 1, 2008 | 08:10 AM
  #45
fbw5595's Avatar
It seems like this is one of the more well liked coilover options. From my research, camber kits are not needed if you obtain OEM ride height with this or any set of coilovers. Correct?
