Grinding noise?
Old Sep 20, 2007 | 08:33 PM
Drewer's Avatar
Bad wheel bearings?
Old Sep 25, 2007 | 02:32 PM
pharrari's Avatar
I have the grinding noise and break squeak from my left wheel. The grind noise is only at full stop. The squeaking varies from 45+Mph stops to Under 10Mph stops.
I'm looking at getting these:
http://store.r1concepts.com/Items/bo...m%20pkg%20129?
This setup should resolve any noise issues.
Anyone vouch for these?
Hope this helps.
Old Sep 26, 2007 | 06:33 PM
r1concepts's Avatar
Is there any rare markings on your rotors? It could be the wear sensors off your brake pads. Check that.
Old Nov 12, 2007 | 12:20 PM
gte959s's Avatar
20 Year Member
sometimes caliper pistons may stick causing the brake pad on one side of the rotor to stay semi-engage even when the brake pedal is released. Most of the time fixing this may mean recompressing the piston when putting new pads on and then monitoring the wear on the new pads. For our car this is easier said than done, with the price of pads and all.
Marlin84
Apr 1, 2020 12:52 PM
magnetism80
Feb 1, 2019 10:00 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
