BBK for a X
BBK for a X
I did a search could not find anything. Can I use a BBK for a rwd for the awd. I am not sure if it is different up front. Thanks Edit. I am also going to running my stock 17's for awhile. Will they fit or will I need to get a spacer.
The front and rear brakes are idnetical on the 2WD and AWD models so there should be no issue. As for wheel fitment with your stock 17s, that up to you to determine using available wheel fitment templates and measurements provided by the manufacturer of the kit you are looking into.
The X's brakes are the same as the RWD G sedan and coupe. More specifically the 03-05 X has the same brakes as the 03-04 G sedan and coupe and the 03-05 350Z.
The limiting factor will be your rim diameter.
seagrasser
May 3, 2022 09:43 AM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
