anyone tried swapping the g37 brakes onto an 06 coupe?
Old Sep 22, 2007 | 09:14 PM
DrewTheSuit's Avatar
like the title says...will it fit with little or no modification
Old Sep 22, 2007 | 09:32 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
still a little to soon for this mod im my mind...
Old Sep 22, 2007 | 09:44 PM
ttrank's Avatar
Grocery getter
That would be sweet. It was my first thought when I saw the G37.
Old Sep 22, 2007 | 10:52 PM
citymunky's Avatar
Cool
Mine too
Old Sep 24, 2007 | 11:54 AM
G35fromPA's Avatar
Doesn't seem worth it - why not go with an already tested application, like Stoptech?
Old Sep 24, 2007 | 12:13 PM
Gilley's Avatar
The G37 brake calipers appear to be much thicker than even the Brembo calipers on the 03-04 G35's. If the mounting points are the same, you may have wheel clearance issues. But we really won't know for sure until someone tries it.
You'll need to wait for a G37 owner to get a BBK (once the G37 kits become available) or get a set from a wrecked G37. Buying them from the dealer would be cost prohibitive.
Old Sep 24, 2007 | 12:19 PM
2drwild's Avatar
Working on getting a set....Not anytime soon, we don't even have prices yet. I had the parts guy look for a few parts and we couldn't get prices to come up. Our sales computers don't even have the car listed in our programs yet.
Old Sep 24, 2007 | 12:29 PM
JOKER's Avatar
CLUB MODERATOR
2k
I already asked.
$500+ for each.
Old Sep 24, 2007 | 02:13 PM
Gilley's Avatar
You will probably need the G37 rotors and brake lines too.
Old Sep 24, 2007 | 02:39 PM
cato's Avatar
SouthernComfort Moderator
Just get the G37!
Old Sep 24, 2007 | 03:26 PM
redlude97's Avatar
The OEM g37 wheels have a much higher offset to accomadate the 14" rotors/calipers so most likely even if it did bolt up, you would have to get new wheels with a higher pad to clear the calipers
Old Sep 25, 2007 | 01:51 AM
JOKER's Avatar
CLUB MODERATOR
I got M rims on with +25m spacers.
I got nothing to worry about. I can fit tractor brakes in there.
Old Sep 25, 2007 | 03:16 AM
ttrank's Avatar
Grocery getter
LOL
M wheels on a coupe with G37 14" brakes would be sweet!!
Old Sep 25, 2007 | 03:45 AM
MEECHIN's Avatar
The rotor diameter and thickness is where the difference will lie.
Then you also have to worry about which rotors to use in there.
My biggest concern wouldn't be the fronts, but the rears.
Let's say the G37 calipers bolt on directly to the G35 coupes.
Now, which rotors do you use?
The G37 or the G35?
G35 rotors may be too small, which means you're screwed no matter what.
G37 rotors may not clear the drum brakes on the G35.
If neither option works you'll need custom rotors.
Mucho dinero there.
Better off going with an aftermarket kit at that point.
-DRU
Old Sep 25, 2007 | 08:50 AM
DRAGMODE's Avatar
First thing I thought was motor swap
