hey new g37 breaks
Old Oct 2, 2007 | 05:25 PM
helldorado's Avatar
Originally Posted by kpopseven
how much are they tho?
maybee i can get a hook up
Call a dealer and ask.
But from experience with the OE Brembos, dealers don't have room to negotiate prices on them and the dealer price is extremely high. I'd realistically expect those brakes to run a minimum of $4-5000 through a dealer.
Old Oct 3, 2007 | 10:05 PM
Skaterbasist's Avatar
Retired SuperMod
larger brakes are not necessarily better, they only add heat capacity in a track situation. Since they are relatively new, a better set of performance pads on the OEM brakes can perform better than the g37 brakes. The g37 brakes will also be heavier. They aren't necessarily "better" per se. It depends on the application and if the bias is similar for the G35.
I never particularly stated nor defined better... I should have been more specific. I just love those large calipers & rotors of the G37 brakes. And just as you stated, larger rotor have a higher heat capacity at the track.
As far as just for daily use, well, the only advantage of the G37 brakes over the 03-04 Brembo's are looks (which is subjective).
Old Oct 3, 2007 | 10:16 PM
ILLicit's Avatar
*patiently waits for someone to smack up their g37s*
Old Oct 6, 2007 | 01:45 AM
terrycs's Avatar
Not sure if the G37S brakes calipers are heavier (I believe they are made by Akebono) The bigger rotors will be since they are not two piece.
Old Oct 8, 2007 | 02:01 AM
kpopseven's Avatar
thanks thanks i will try to call when i can and post up the price ... T_T i hope they are cheap
Old Oct 15, 2007 | 05:53 PM
bikinilust's Avatar
let us know how that goes...
Old Oct 16, 2007 | 09:56 AM
G35fromPA's Avatar
Not only are they not necessarily better, but they could make things worse on a G35. Remember, unless someone knows differently (i.e. they have taken apart an Akebono caliper, and seen the parts numbers for the G37) the caliper pistons and brake MC are likely to be sized differently. You could slap those on and end up with much longer braking distances.
Remember, a lot of engineering goes into braking systems. Bigger isn't always better by default, even with added thermal capacity. There are a lot of variables at play here - brake bias, weight, caliper stiffness, etc.
Old Jun 18, 2009 | 06:06 PM
07PEARL6MT's Avatar
Anyone have pictures on a G35 with the G37s brakes installed? I assume they clear the sport 19's no problem?
Old Jul 4, 2009 | 10:43 PM
jhurst's Avatar
Ya they clear, twin001 did a DIY on a G37 brake install on his G35 in which he had stock 19s. They will clear pretty much any 19" wheel.
MR M37s
Oct 30, 2015 08:32 AM
Hotdawwgman
Sep 18, 2015 04:19 PM
Fire0nic3
Aug 31, 2015 03:18 PM
bdnbfrank
Aug 17, 2015 02:09 PM
bickfordbft
Jul 20, 2015 07:57 PM
