OEM 19" Tire Question... again
Old Oct 11, 2007 | 02:41 AM
chuckd05's Avatar
ive searched but i get conflicting information...
I already have two 245/35/19s that im going to use in the front, near mint...
and i need to get rear tires
the size i want is 255/40/19 ???
or can i go wider ??? whats the correct size i should use... ?
thanks in advance
Old Oct 11, 2007 | 02:54 AM
mwarsh1's Avatar
You Should Go With The Oem Spec, Becasue If You Put To Wide A Tire It Wont Fit The Rim Correctly And It Will Look Like A Drag Radial Type Of Tire.
Old Oct 11, 2007 | 03:15 AM
Beebo's Avatar
OEM rear is 245/40/19
255/40/19 is fine dont go any wider
o and 245 for the front is fine thats what i have
Old Oct 11, 2007 | 03:35 AM
chuckd05's Avatar
alright cool. i had just got these fronts (the 245/35/19) i couldnt buy another two....
im gonna go with 255/40/19
thanks
Old Oct 11, 2007 | 01:33 PM
chuckd05's Avatar
i keep searching...
why do some people put 40s up front and 35s in the rear? dont you want it to be the same height tire, or even a touch higher???
255/40/19s is what im going to order prob today...
how much off of stock size would my setup be
245/40/19 and 255/40/19s in the rear...
Also do 350z h techs sit nicely around oem 19s? or should i go lower?
i have tein s techs but they are off my car currently.. which would be better
Old Oct 11, 2007 | 01:49 PM
redlude97's Avatar
Originally Posted by chuckd05
i keep searching...
http://www.miata.net/garage/tirecalc.html
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
BlueBelleG35x
Jul 23, 2015 02:10 PM
