DIY Coilover install
I have installed them myself.
You will need a spring compressor since you have to take off the top of the OEM shock and put them on the basics.
Impact (Air) gun would makes things easier.
Jack stands.
A good set of sockets that will let you put enough torque to break (Loosen) the bolts on the bottom of the shocks.
Easy as cake
Jack stands.
Easy as cake
would think that a spring compressor would be the only tool rather more difficult to come by.. good luck with the install, dont be afraid to go to your local tire shop if something doesnt seem right
ENVautoDetailing.com
where in socal are you located? you can rent a spring compressor from your local autozone, they just request a deposit that is refunded upon return of the tool.
-GP-
-GP-
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
yassy
Aug 9, 2015 07:31 PM
