After 350evo installed
Old Dec 7, 2007 | 10:25 PM
lekker_droom's Avatar
I got my 350evo a arms installed and just had a general question about them.
The car feels a little rougher now, meaning, that is almost feels like the front end is loose or something. I had a top notch shop specializing in suspension setups install them. They were very impressed by the quality of the 350evo arms.
One thing is that the 350evo arms don't have a poly or rubber cone bushing. Could this be a result that is natural from a non-poly or rubber cone bushing. Am I just getting even more "feedback" from the road?
Nothing else changed other than replacing stock a-arms with the 350evos. Springs were already on. Or could something possibly be loose or would it be blatantly obvious if something was loose?
Thanks!!!
Old Dec 8, 2007 | 04:23 PM
myG35ZX's Avatar
Unless they made a mistake and did not tighten the camber adjustment plates, what you are feeling is more road feel. I have them and you feel much more than the OE, but I'm curious when the bushings wear out where to get replacements as 350Evo help is non-existant.
Old Dec 8, 2007 | 06:24 PM
Thanks.
There are no bushings to speak of with the 350evo set up. I thought it strange too but apparently it's a better setup. Its mono-ball and spherical bearings.
Old Dec 8, 2007 | 06:29 PM
UnluckyCharms's Avatar
SPL are the same setup. I have the same experience with my SPLs, so I'm really curious to hear peoples' responses....
Old Dec 8, 2007 | 06:32 PM
myG35ZX's Avatar
Sorry, I used "bushings" instead of heim joint rod-eye or whatever the pivot points are called. And my understanding is that the SPL still uses rubber bushings.
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
