G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Brakes & Suspension (https://g35driver.com/forums/brakes-suspension-164/)
-   -   Anyone ever change just front springs? How's it ride? I just wanna lower the front. (https://g35driver.com/forums/brakes-suspension/192080-anyone-ever-change-just-front-springs-hows-ride-i-just-wanna-lower-front.html)
obsdnoblivion Dec 11, 2007 10:54 AM
I mainly just want the front and back to have even gap. If I lower just the front, will the car be riding silly? The front bouncing a little and the rear end bouncing more? Anyone done this?
SLOTOY1269 Dec 11, 2007 04:03 PM
Coupe springs will lower you car about half inch. That should make it about level. I have some front only if your interested pm me your zip I'll let them go cheap.
02themax Dec 11, 2007 06:05 PM
I did it on my Maxima, I would do both if I were you. The rears take literally 20mins for both sides. You'll have a much tighter and bouncier front end which could get dangerous if you hit some bumps while going through a curve.
DaveB Dec 11, 2007 07:10 PM
Here's my 03 on Z springs in the front and coupe springs in the rear. I came up with the idea of teaming the Z/coupe springs because I wanted an even drop while using OEM parts. I think it's a pretty common setup now.
http://i147.photobucket.com/albums/r...6/3bday062.jpg
ttrank Dec 11, 2007 07:12 PM
You don't want to just change one set of springs, it throws off the dynamic balance of your car too much. I would always get matched kits. Most aftermarket ones are made to be level. Before my coilovers I had H&R made for the sedan which put it right at the top of the tire front and rear.
jazzyb Dec 11, 2007 08:05 PM
I've done that while waiting for my coupe springs to arrive. Actually I had Z springs all around but the back was riding too low so I put the original springs back on the rear. With Z's up front and original in the back the car was 'pitched' forward a bit. Easily fixed with the seat controls but the other passengers are out of luck. Plus the ride dynamics were off.
Gilley Dec 11, 2007 11:44 PM
Damn, I'm still undecided about using Z or G coupe spring in the rear. Good thing swapping the rear springs is pretty easy.
© 2026 MH Sub I, LLC dba Internet Brands
