Quick front rotor recommendation.
Old Dec 27, 2007 | 12:16 AM
KapnK's Avatar
I posted this question in the tech area but I figured some of you might not make it over to that neck of the woods. Here's the link to the vitals:
https://g35driver.com/forums/brakes-suspension/194617-good-oem-2003-g35-5at-sedan-vdc-abs-front-rotor.html
Thanks,
Steve
Old Dec 27, 2007 | 12:34 AM
sliderg35's Avatar
I'm a big fan of the Pro-Slot cross drilled rotors. I matched them up with Hawk HPS pads. They don't leave any dust and they last forever (almost).
Old Dec 27, 2007 | 12:38 AM
KapnK's Avatar
I like that idea, myself but the link shows my quick oem need. I'm just trying to get a decent parts store rotor and pads, quick and inexpensive the prime objective. I also don't know if the vdc, or abs require any consideration(ie: if or what parts need to be swapped to the new rotor as I haven't disassembled it). It's an '03 5at auto sedan, non-brembo.
thanks,
steve
Old Dec 27, 2007 | 01:56 AM
5150DS's Avatar
Racing Brake slotted, both front for $109 (prices are for two). Drilled and slotted for $119. The Duralast OEM replecements from Autozone are $104. Racing Brake is supposed to be good quality and lighter than stock. Also make sure you replace both, not just one.
http://www.racingbrake.com/INFINITI_G35_s/211.htm
Old Dec 27, 2007 | 08:41 AM
BuckeyeG's Avatar
They arent that hard to change out just remove the caliper and pads and they come right off . You may need a rubber malot to get the old rotor off as they may be rusted together in the back. You will also need a piston depressor to get the new pads on. I would also say replace both rotors at once.
Old Dec 27, 2007 | 08:48 AM
Mmagic76's Avatar
Site says it's $109 each, are you sure it's for two?
Old Dec 27, 2007 | 10:08 AM
chrisg_101's Avatar
R1 Concepts has a bunch of different rotors for the G. Some are pretty cheap. Check them out
Old Dec 27, 2007 | 10:10 AM
ttrank's Avatar
Grocery getter
You are right, the price is $109 for each rotor.
These are a good product and you can even upgrade to 4-piston calipers down the line from RB.
Old Dec 27, 2007 | 06:37 PM
5150DS's Avatar
Oops, my mistake.
jsimonk
Dec 22, 2023 03:49 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
miata007
Aug 17, 2015 04:36 PM
whatacar
Canada
Aug 13, 2015 07:33 AM
