Clicking noise by the rear tire
Old Dec 27, 2007 | 09:52 AM
dunglan7's Avatar
I just put my stocks back on and now I have a clicking noise out of my rear driver side. Every time I turn the wheel and slowly hit the gas I hear the noise. Could it be something rubbing although it sounds more like a popping noise. Any inputs?
Old Dec 27, 2007 | 11:00 AM
03silver's Avatar
e-brake rubbing somthing?
Old Dec 27, 2007 | 12:00 PM
EvolutionGSR's Avatar
are you sure it didn't do it before you changed your tires?
The only thing I can think of is that rear axle TSB. Just needed some tightening.
Old Dec 27, 2007 | 12:19 PM
Sportcoupe35's Avatar
Take it to the dealership. They'll lube the rear axal or something like that. Its a common problem in G35s....something in the rear needs lubing.
So when you're stop and start to accelerating almost immediately a little pop sound or a click sound occurs correct?
Old Dec 27, 2007 | 04:01 PM
dunglan7's Avatar
^ Yes that's exactly it. The noise starts right when I start and stop.
The noise started when I put the stocks back on. I didn't have that problem when my m45 wheels were on.
Old Dec 27, 2007 | 04:15 PM
Its probably that...I think it's even a TSB. Bring it to them and describe to them (don't mention the part about swapping the wheels)....and they should know exactly what you're talking about.
Old Dec 27, 2007 | 04:17 PM
dunglan7's Avatar
^ My car is out of warranty so it there any other way to do this without bringing it in?
Old Dec 27, 2007 | 08:59 PM
w0ady's Avatar
fgc moderator
call infiniti. the axle tsb is widely known. they might still cover it.
Old Dec 27, 2007 | 09:49 PM
Texasscout's Avatar
Did you look for a rock or a nail stuck in it?
Old Dec 27, 2007 | 11:25 PM
dunglan7's Avatar
^ Stuck in the axle?
Old Dec 28, 2007 | 08:56 PM
Texasscout's Avatar
Stuck in the tire...
Old Jan 2, 2008 | 07:56 PM
FastrColor03's Avatar
torqued yer nuts?
missing spacer?
Old Jan 2, 2008 | 08:33 PM
Texasscout's Avatar
Originally Posted by FastrColor03
torqued yer nuts?
Get some boxers....
Old Jan 3, 2008 | 06:12 PM
ttrank's Avatar
Grocery getter
It's the axle click TSB. I have the same issue and will be fixing it soon.
Let me see if I can find the TSB for you
Old Jun 19, 2008 | 11:06 AM
I Scare's Avatar
I think i have this problem. It just happened. I hear the clicking noise when I step on the gas or brake. It's fine when I hit Reverse. Is this still common.
