HELP! OEM brake shims
Old Dec 28, 2007 | 08:40 AM
dunglan7's Avatar
I need help on the oem brake shims. My car is making this screeching noise. I found out that it's the shims that are attached to the calipers not the pads. There is a metal part that is pointing outwards causing it to rub up against the wheels. Does anyone know if I installed them wrong? I can't bend it back and I need it to hold on the pads to the calipers. Anyone happen to have pictures of how the non-brembo calipers look?
Old Dec 28, 2007 | 09:38 AM
Wezz's Avatar
https://g35driver.com/forums/showthr...or+replacement
This should help you
P
Old Dec 28, 2007 | 09:50 AM
dunglan7's Avatar
^Thanks.
miata007
Aug 17, 2015 04:36 PM
whatacar
Canada
Aug 13, 2015 07:33 AM
sahizzle110
Jul 29, 2015 11:36 AM
mushu
Jul 15, 2015 03:55 PM
