Cutting Aftermarket Springs
Old Dec 31, 2007 | 08:06 PM
6mt2005's Avatar
Over a month ago i lowered my car on Tein Tech H springs so what happened was the front got a nice drop but the rear is about 1/2 higher than the front. Cutting the Rear aftermarket springs is that bad? Is the ride quality going to change?
Old Dec 31, 2007 | 08:21 PM
Adon's Avatar
search up "springmount mod"
Old Dec 31, 2007 | 08:35 PM
doctorG's Avatar
The rear is suppose to be higher. It looks better, and if you load ur trunk or have people sitting in the rear, it evens out. It's a lot better then having the front higher then the rear. Which is what will happend if u cut the rear.
even if you manage to get the front and rear to even out, once people sit or the springs starts to sag, the rear will be lower and ur ride will have a speed boat effect.
1/2 higher isn't all that bad man. but its ur car. the rear spring is thinner then the front, and it should settle a bit.
Old Dec 31, 2007 | 08:36 PM
Jason@Riverside's Avatar
cut the rear spring mounts...
if you do not want any down time, buy a new set, they are not much...
PM me your zip...
Old Jan 1, 2008 | 04:34 AM
Calvin's Avatar
Overglorified Altima
cutting springs =
cutting spring mounts =
jilljann1
Jul 21, 2020 08:12 AM
DRG35R
Sep 16, 2015 05:33 AM
twentyeggs
Sep 11, 2015 03:58 PM
Albanian122
Sep 7, 2015 07:41 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
