Tires
Old Jan 4, 2008 | 01:53 AM
Jum's Avatar
Jum
Florida G35 Owner
Tires
I have the full 06 350z suspension... my rear tires are getting OWNED.... i just put them on and they are almost bald in the back because of the drop i believe...
Any suggestions? Do you think i need an alignment?
Old Jan 4, 2008 | 08:15 AM
cato's Avatar
SouthernComfort Moderator
Your "drop" is probably causing alignment issues. Camber kit?
Old Jan 4, 2008 | 12:04 PM
Jum's Avatar
Jum
Florida G35 Owner
Camber kit with an 350z suspension!!??!
Old Jan 4, 2008 | 12:36 PM
escobar929's Avatar
you should have gotten an alignment after three weeks of the install
that would have told you if you need a camber kit or not
Old Jan 4, 2008 | 12:40 PM
Calvin's Avatar
Overglorified Altima
You never got an alignment after the drop?
Old Jan 4, 2008 | 09:49 PM
Jum's Avatar
Jum
Florida G35 Owner
ahhhhhh is it too late?
Old Jan 4, 2008 | 10:32 PM
labguy94's Avatar
As was already mentioned you really should get an alignment after you drop the car. The front wheels do not allow for camber adjustment - but the rears do. I dropped my '05 sedan on coupe sport struts, z springs in the front and coupe sport springs in the rear. The alignment shop was able to get the rears right within sedan camber spec.
What really could be causing the tire wear (along with the negative camber) is the toe is probably out of alignment too. By getting an alignment you'll save your new tires in the future (even though these may be shot)...
For more info on alignment and suspension mods for the sedan - search for threads and comments from gsedan35 (resident guru) and gdup35sedan (who works on alignments).
Here is another thread that may be useful:
https://g35driver.com/forums/showthr...spension+sedan
Here is a good link on overall info for alignments:
http://www.familycar.com/Alignment.htm
Hope this helps!
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
