Pic Request: Stillen Bar
Old Jan 23, 2008 | 10:13 PM
citymunky's Avatar
Exclamation Pic Request: Stillen Bar
Picture Request for Stillen Rear Bar
I just installed my Stillen Front Strut Bar (or Strut Tower Bar),
and now I'm thinking about getting the Stillen Rear Bar,(On Sale for $145.20 with free shipping)
but I'm not sure if it will clear my sub box (My sub box has a tab on each side that be re/moved to gain access to the mounting points.)
So, if you have a Stillen Rear Bar, can you take pictures from different angles,
it would be very helpful, THANKS
Old Jan 24, 2008 | 01:22 PM
g7x5's Avatar
https://g35driver.com/forums/showthr...illen+rear+bar
Old Jan 24, 2008 | 04:51 PM
citymunky's Avatar
Thanks^
Old Jan 24, 2008 | 06:08 PM
citymunky's Avatar
Question Will it work???
Here a picture with the tabs moved(I can make them move back too)
Since it seems the rear bar will not fit with my sub box in the way, I thought of a way I might be able to make it work. I just not sure if it will be safe. The plan is to use longer bolts and spacers.
Step 1)-Slide washers on the longer bolts.
Step 2)-Slide bolts with washers thur Rear Strut Bracket
Step 3)-Slide spacers on bolts behind the bracket
Step 4)-Install brackets and bar (Using Stillen Instructions)
What do you guys think?????
Old Jan 30, 2008 | 12:05 AM
nfo184's Avatar
how bout just notch out the sub box where it touches with a jig saw and have the strut bar fit flush up against the sub box??? i have mine on and it fits fine
lag35driver
Northern California
Sep 17, 2015 12:32 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
