Another SPC problem
Another SPC problem
ok so after reading many threads on the SPC camber kit for the fronts on the coupe... ive read about the clunking/knocking noise that comes from driving
now its not from going over a bump.. you only hear it when you first take off and as you slowly accelerate the knocking/clunking noise gets faster and after about 20MPH you just dont hear it anymore.... ive checked and re-checked everything... everything is tighten down to torque spec and i never had to use spacers or the ABS bracket given
so do any of you guys know what this is from its only coming from the passenger side and its not from hitting the top of the fender beacause its NOT when i go over bumps it when i first accelerate
BTW this only happens some of the times... the other times its perfectly fine and you dont hear anything at all
itgogitrev
Sep 23, 2015 07:08 PM
DRG35R
Sep 16, 2015 05:33 AM
