how low 2 go
Old Feb 14, 2008 | 10:13 PM
Dho42's Avatar
i got 20's rollin with tein s-tech i dont rub. but i also have my fenders rolled. car is fine.
Old Feb 14, 2008 | 10:20 PM
redlude97's Avatar
Originally Posted by G_whip
i dont wanna scrape the ground but i still wanna go over speed bumps regular and i dont want camber or rubbing to be an issue
Good luck, I scrape still occasionally on alot of stuff and 350z h-techs is a conservative drop
Old Feb 14, 2008 | 10:24 PM
SlooberTooth's Avatar
Is it hard to DIY with the springs? How much time does it take?
Old Feb 14, 2008 | 11:23 PM
Dho42's Avatar
3-4 hours without a lift. 2 hrs with a lift
Old Feb 14, 2008 | 11:35 PM
O HELLA OEM's Avatar
damn those axis shines are growing on me!
Old Feb 14, 2008 | 11:39 PM
Corvettekid's Avatar
I got some sevas' on my car(well will again when the weather gets nice). I have no drop, but i want to. What would you recomend? Would s-techs be too much? I live on Long Island, so the roads arent that nice all the time. Any input is appreciated...
Old Feb 15, 2008 | 12:02 AM
Beebo's Avatar
Yes, I have the exact setup I recommended. I spent ~$200 on the springs and ~$150 on the rear camber kit. ~.8" drop all around
you wont need a canber kit if its only ~.8 drop? id like that but no camber kit...
Old Feb 15, 2008 | 12:56 AM
redlude97's Avatar
You will want a rear camber kit, but won't necessarily need a front kit. You'll likely get a little bit of excess camber wear in the front, but you can just flip the tires when needed
Old Feb 15, 2008 | 01:30 AM
dut's Avatar
dut
At Least 2.5"
Old Feb 15, 2008 | 01:42 AM
if you dont get a camber kit when you drop, what is the life span of the tires?
Old Feb 15, 2008 | 01:46 AM
dut's Avatar
dut
Thats not a good question. Hahaha.
DRG35R
Jan 31, 2016 07:14 AM
Rinaldi
Dec 2, 2015 05:29 PM
aaron3719
Sep 29, 2015 10:12 AM
wow600rr
Sep 28, 2015 11:50 AM
Detailed Image
Sep 28, 2015 07:04 AM
