Camber/Spec Sheet?
Old Feb 22, 2008 | 04:49 PM
TurboDreamzG's Avatar
Camber/Spec Sheet?
Hey guys. I've been reading up and finally decided on a suspension set up. I've just received my tein basic coilovers and i'm waiting for my SPC Rear and Front Camber/Toe Caster kit to come in before I do the installation. My only question that I had that I couldn't find on the forums is.....when I install my camber/toe kit on my car and lower the car on coilovers and have it aligned, how low can i actually go until it is out of range to be aligned back into spec? I see alot of guys completed slammed on the coilovers as low as it goes and I guess I'm wondering if SPC kits can actually do the job of bringing that much negative camber back to a oem spec or atleast close. I also see how you guys post up your spec numbers from your alignment, just wondering what are good numbers, i'm not familiar with the spec sheets and if i request one after i align my car i want to know what the heck i'm looking at. thanks guys. lol.
Old Feb 23, 2008 | 12:37 PM
G35sedan03's Avatar
the new SPC rear kit allows for +/- 4 degrees and the front i think it's +/- 5 if i remember right. that's a lot of range and if you were slammed you probably would be pushing towards the max range of those kits. i think redlude can answer that much better. send him a pm.
Old Feb 23, 2008 | 01:25 PM
bigc's Avatar
Wings Nation
Factory alignment specs can be found here:
https://g35driver.com/forums/wheels-tires/203207-factory-alignment-specifications-specs.html
Direct link: http://psedog.com/cars/fsm/g35/
choose your car type (coupe or sedan), then your model year, then search 'Alignment' in the PDF.
Old Feb 23, 2008 | 09:05 PM
Thanks big c, that helped out alot. i'll shoot redlude a pm though for any other questions. Thanks.
Ednica87
Sep 5, 2015 02:59 AM
Jiggerjuice
Aug 31, 2015 11:49 AM
