Can compression rod bushing look OK but actually be bad?
Old Feb 22, 2008 | 08:14 PM
ericlee303's Avatar
How to remove compression rod?
Hey guys, so I've been sucked into the mysterious world of G35 problems
I'm trying to get rid of the rattling clunking in the suspension on the driver's side, and I just want to see what your experiences were.
I tried replacing the upper control arm and ball joint but that did not help much.
I've bought a compression arm for $300 but I want to make sure that's the problem before I keep throwing money at this pig.
My mechanic said the bushing in the compression rod looked fine, but when I took a look at it myself, it was ripped half way around on the top side.
What a moron. He only looked at the top side.
The question is, is removing the rod as easy as it looks, just undo the nut and ball joint, and slide it off?
THANKS FOR HELPING NOOB HERE
Old Feb 22, 2008 | 10:19 PM
Scrooge's Avatar
Compression rod (Radius rod)
Front
RADIUS ROD
REMOVAL
1. Remove tire with power tool.
2. Remove brake caliper with power tool. Hang it in a place where it will not interfere with work. CAUTION:
o Avoid depressing brake pedal while brake caliper is removed.
3. Remove fixing bolt and nut in axle side of radius rod with power tool.
4. Remove rear lower link and coil spring.
5. Remove fixing bolt in lower side of shock absorber with power tool.
6. Remove fixing bolt and nut in axle side of front lower link with power tool.
7. Remove fixing bolt in rear suspension member side of radius rod with power tool, then remove radius rod from vehicle.
INSPECTION AFTER REMOVAL
* Check radius rod and bushing for any deformation, crack, or damage. Replace if necessary.
INSTALLATION
* Install in the reverse order of removal.
CAUTION: Refer to component parts location and do not reuse non-reusable parts.
* Perform final tightening of rear suspension member and axle installation position (rubber bushing) under unladen condition with tires on level ground. Check wheel alignment.
Old Feb 23, 2008 | 11:17 PM
ericlee303's Avatar
Thanks, are you sure that's the procedure for the front compression rod? I didn't think you had to remove the spring, strut, etc...
Old Feb 23, 2008 | 11:53 PM
Scrooge's Avatar
It just whats on alldata.
Old Feb 24, 2008 | 09:08 AM
Q45tech's Avatar
Just as background info. Infiniti [Q, J, G, M] has always had front suspension components that wear and get replaced due to rubber cracking since 1989. Just a common item every 30-60k..........wear and tear from trying to have excellant handling with a good ride.
Whether they were called upper links, tension rods, or radious rods.
Same with noise, road dirt and water get inside rubber and squeek against metal interface.
Old Feb 24, 2008 | 02:02 PM
ericlee303's Avatar
Thanks!
Old Feb 28, 2008 | 11:50 AM
ericlee303's Avatar
Compression rod solved the problem.
The old bushing looks OK from a distance, but if you look up close, there are stress cracks in it, and the bushing itself looks off-center.
My mechanic was 99.9% sure that the bushing was OK, but obviously he doesn't know anything about this issue.
Old Feb 28, 2008 | 12:00 PM
freak21s2k's Avatar
is the compression rod the same thing as the sway bar? im confused, cuz im gettin the same weird noises also...
Old Feb 29, 2008 | 03:22 PM
ericlee303's Avatar
Compression rod is not the same as sway bar. The sway bar spans across the car and connects the suspension on both sides. This rod goes from the frame behind the front wheels to each lower control arm on each side.
Old Mar 1, 2008 | 01:04 AM
Jeff92se's Avatar
Red Card Crew
Would you be willing to ship me your bad one? If you aren't going to do anything with it?
Old Mar 1, 2008 | 06:08 PM
freak21s2k's Avatar
ic..so that loud knocking noises are usually due to either broken endlinks or bad compression rods? i needa get that checked out. noise is gettin annoying. =\
Old May 5, 2009 | 03:36 PM
AARONHL's Avatar
After replacing the compression rods, is an alignment necessary?
Will new compression rods give you an overall smoother ride? Or just stop the creaking and popping while entering a driveway? Because it feels like I have some rumbling up front while cruising at speeds.
Old May 19, 2009 | 08:29 AM
LEK's Avatar
LEK
That Guy
wow i have that same annoying clunking squeeking when i drive...
Old May 21, 2009 | 08:18 PM
melo's Avatar
i had the same problem a few months before, and i got my G checked by some machanics and they all said that i needed to change the lower control arm or the compression rod...
then i took it to the dealer, and they checked it over... and it was juz the loose of the ball joint...
do it urself, or take it to any workshops and tell them to tighten the ball joint, it will only take like 10 mins?
the dealer charged me $60+... thats y dealer is always my last choice LOL
Old Sep 24, 2009 | 11:46 AM
davesxx01's Avatar
Sorry to revive an older thread. I have a klunking noise in my left front also. Only on small little bumps in the road. Local shop says they can replace just the bushing and it costs $23 bucks? Others say the whole arm (dealer) for big bucks.
Dont feel or hear any squeaking, just metal on metal klunk like something is loose.
Checked sway bar endlinks and they felt good.
Opinions?
