My Friend is Having Problems
Old Mar 20, 2008 | 12:36 PM
Hi-TechG35's Avatar
So my friend just purchased a used 03 Coupe with 55k in mileage roughly. So he sent me an email telling me he felt his car was having some problems and wanted to know what I thought. So I figured I ask you guys for some opinions before sending him off tot he stealership.
1.When you let go of the wheel the car veers to the left; it doesn't stay straight.- I told him sounds like he needs a wheel alignment
2.When he clicks the lock button on the remote the horn doesn't beep. The lights just blink to let him no the door is locked.-I suggested a fuse
3.When he turns the car off and takes the key out of the ignition the dome lights don't come on. he said he checked the on/off switch and that doesn't do anything.- Again I suggested checking the fuses.
4.Rattling- lol I told him get used to it.
Well if you guys have any sugestions let me know so I can share some thoughts with him.
Thanks guys/gals!
Old Mar 20, 2008 | 12:38 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Thanks guys/gals!
1. Go get the alignment checked, if its out, get it fixed, if its not out, cross rotate the front tires or get new ones.
2. Hold down the lock and unlock at the same time until the horn beeps.
3. Most likely a fuse
4. Yur fukced on that one!! haha
-GP-
Old Mar 20, 2008 | 12:41 PM
cremaster's Avatar
1. he could be experiencing radial pull. i got my car aligned about 7 times in the last month (long story, hit potholes, etc.) anyway, the last time, the alignment was right on but i still got pull to the right. said it was probably radial pull and they made adjustments to compensate for it. now it drives straight!
Old Mar 20, 2008 | 12:43 PM
JOKER's Avatar
CLUB MODERATOR
-GP-
or the bulb.
Good luck.
Old Mar 20, 2008 | 12:44 PM
I'd take it right back, making adjustments in the alignment to solve a radial pull?!?! are you kidding me? That would mean that your alignment is out of spec to compensate for the pulling that the tires are causing... A RADIAL pull is caused by one or both of the front tires.
-GP-
Old Mar 20, 2008 | 12:45 PM
Originally Posted by JOKER
or the bulb.
Good luck.
assuming the guy has half a brain he would have already checked the bulb... damn you Joker
-GP-
Old Mar 20, 2008 | 12:51 PM
Q45tech's Avatar
What happens when friends don't pay EXPERTS to do prebuy inspections and list the $3,000 in defects usually not repaired by average owners under warranty and just wear and tear in 5 year old 55k entry lux cars.
Sounds like it might have been wrecked and repaired [poorly as normal] since most don't hire consultants to oversee paint and body shops.
Since insurance pays paint and body the shops do the minimal as demanded by insurance. Doing too much leads to no business from insurance.
The dealer will happily for a fee list recommended repairs.
Old Mar 20, 2008 | 01:16 PM
JOKER's Avatar
CLUB MODERATOR
-GP-
I thought that too but OP only mentioned him trying the switch.
Old Mar 20, 2008 | 01:23 PM
cremaster's Avatar
-GP-
yeah, i know but the pull was ever so slight so the "adjustment" was just enough. i had it aligned at 3 different places to make sure the alignment was right but i still got the pull and my steering wheel was just a bit off. so, i just told the last place to try and make the adjustment w/o messing w/ the specs and now it's good!
g35Serge
Sep 30, 2015 11:43 PM
Detailed Image
Aug 19, 2015 08:38 AM
Detailed Image
Jul 24, 2015 12:31 PM
Detailed Image
Jul 21, 2015 08:50 AM
Detailed Image
Jul 16, 2015 02:46 PM
