Brake Fluid Level?
Brake Fluid Level?
On the brake fluid reservoir there are max and min, mine is right in the middle of the two, will I notice alot firmer braking if I fill it to max? Also, what would be some good brake fluid to add? Oh, I have the apracing BBK as well and the stillen brake line upgrade.
1) No it won't.
2) There are alot of quality fluids out there. Question is, wouldn't you have put some on when you installed the bbk?
3) Just a guess but if you bbk has alot more piston area vs oem, your pedal travel will increase.
Thanks, I bought the car with the BBK, I just thought it might firm it up a little. Since I wont be adding any fluid, Ill just leave it to the dealership when I take it there to maintain it.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
DRG35R
Sep 16, 2015 05:33 AM
