Need Help!! ASAP
Old May 3, 2008 | 06:34 PM
s_saeed's Avatar
Need Help!! ASAP
Just finished installing an Eibach Prokit on my 2003.5 Sedan. The alignment is way off which is what I was expecting. The problem is that now my SLIP and VDC light comes on and stays on. I'm pretty sure I routed the brake line and Wheels speed sensors wires correctly but i'm going to check out tomorrow for sure. Does anybody know why this may have happend??? Thanks in advance
Old May 3, 2008 | 11:06 PM
Gsedan35's Avatar
On the rear suspension where you loosened the toe cam bolts on the lower control arm, make sure that the little dot's that are stamped into the washer is pointing straight down on both sides. If they are uneven, that might trip out the VDC and slip light.
Old May 4, 2008 | 12:16 AM
s_saeed's Avatar
Going to try that first thing tomorrow. When I loosened and tightened them they went all over the place. I do remember seeing the dot and am pretty sure it was not pointing down when I finished. So it needs to be facing straight down?? Thanks for the quick response.
Old May 4, 2008 | 02:57 AM
Gsedan35's Avatar
Straight down, though IIRC straight up would be the same thing, I'm going by what I know I did.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
esy
Sep 1, 2015 09:10 PM
Ray Feta
Aug 20, 2015 08:46 PM
poker_lamina
Aug 14, 2015 12:57 AM
