Problem with Camber and Toe
Old May 10, 2008 | 04:27 PM
upatel225's Avatar
Talking Problem with Camber and Toe
I have a 2005 G35 coupe with stock suspension, when i took it to get aligned they said the rear camber and toe are stuck negative and it looks like the rear springs are sagging. has anybody heard anything about this and if so whats an easy fix. I also have excessive wear on the inner tires in the rear.
Old May 10, 2008 | 08:59 PM
citymunky's Avatar
You need a Rear Camber kit, to readjust the camber and toe angles back to factory spec's. SPC is a good brand brand and it's not that bad on the wallet.
Old May 10, 2008 | 09:28 PM
Texasscout's Avatar
Remember....
No fat chicks in the back!
Replace the springs (easy in the back 1 hr max) or install a camber kit.
Old May 10, 2008 | 09:32 PM
upatel225's Avatar
Is that really why they are sagging cuz of the weight??
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
linedr89
Aug 17, 2015 05:11 PM
jimNC
Jul 25, 2015 05:47 AM
