I need help identifying this part!
Old May 26, 2008 | 09:41 PM
dosa's Avatar
Hello guys,
I've been hearing this weird loose noise coming from the rear suspension of my car and today I finally put it on the lift. Right away I saw the end link that holds the rear swaybar hanging down and this is the piece that CRACKED:
Anyone have any idea what the name of this part is? Any help would be appreciated. Thanks!
Old May 27, 2008 | 01:24 PM
1SickVeilsideZ's Avatar
Sway bar links... Is it the driver or passenger side? Also did it break off the sway bar itself or the control arm, you might have to replace one or the other which ever it broke off, the link connects to the sway and then the control arm.
Old May 27, 2008 | 07:36 PM
dosa's Avatar
I believe the sway bar link is the slim metal piece.. I'm looking for that triangular black piece that's cracked.
I contacted a local dealership and the parts guy said it's called the stabilizer bar bracket. It costs about 20 dollars. I hope this is the right part because I ordered it.
This is the passenger side. Right now my swaybar is floating without the end link and that bracket which mounts to where the springs are held I believe..
Old May 27, 2008 | 07:44 PM
JOKER's Avatar
CLUB MODERATOR
1) Stabilizer bar 2) Bushing Bushing Back 3) Clamp Clamp Back
4) Stabilizer link Right 5) Stabilizer mount Back
Old May 27, 2008 | 08:00 PM
dosa's Avatar
Thanks JOKER!
Old May 27, 2008 | 08:51 PM
JOKER's Avatar
CLUB MODERATOR
check with RICK if it's sold separately
s8n
Jul 31, 2015 01:37 AM
s8n
Jul 30, 2015 04:47 AM
